03 catback
Er....that would take a custom job at your local car/body shop. Check the clearance so you can fit tips.
Dual exhaust works like this....it's basically a straight pipe down leading into a boxlike containment and two pipes lead from that. The only concern is whether you have enough clearance for the box to clear without scraping the bottom.
ORIGINAL: 03Sleeper
if im not mistaken, the channels below the car are different. but u may wanna check w/ a V6 if im right. you may also wanna seal one of the pipes so u don't loose back-pressure which cause u to lose torque. (I think u should go for it, but check if it fits first!)
