air/fuel adjustment
Old Jul 21, 2009 | 05:24 PM
accordkid16's Avatar
Default air/fuel adjustment
i installed an intake and the car bogs because it's getting to much air and not enough fuel...can anyone tell me where the air/fuel adjuster is on a 92 accord f22a1?
Old Jul 22, 2009 | 12:33 AM
finch13's Avatar
An intake won't cause that problem... are you sure you reconnected everything after you installed it?
Old Jul 22, 2009 | 02:48 AM
jasonfridlund's Avatar
Default it could be
the crank case vent tube. without that too much pressure builds up right?
Old Jul 22, 2009 | 09:16 AM
everything is hooked up right...when i start it and hit the gas a little the engine check light comes on and the rpm's go up to 2k and back down to 1k until i drive it, but sometimes when im at a red light or stop sign it will start again.
Old Jul 22, 2009 | 10:40 AM
00AccordLX5spd's Avatar
Registered User
You need to find out what code the check engine light is throwing.
Did you reset the ECU after installing the intake?
Sounds like your car is in "closed loop mode" which could explain the bogging down.
I would start by resetting the ECU (Pull the "radio/backup" fuse form the underhood fuse box. leave it out for 15 or 20 seconds, then reinstall it.)
Start the car and let it fully warm up before driving it. The ECU may need to "re-learn" the settings since you installed an intake.
If the CEL comes back on after you reset the ECU, get the code and post it here.
Old Jul 22, 2009 | 01:21 PM
botang47's Avatar
maybe he means an intake manifold?
theres no way an intake will cause too much trouble unless it was installed incorrectly
Old Jul 22, 2009 | 02:05 PM
yes. im thinking he meant the intake manifold. A friend of mine rebored his to increase flow and it screwed up his ecu for about 5000 miles.
Old Jul 23, 2009 | 08:54 PM
no it's a short ram air intake the car drives fine but im just worried obout the reving
eleiko
Jun 15, 2011 10:46 PM
deserthonda
Dec 31, 2007 09:16 AM
mpanelli
Apr 18, 2006 08:32 PM
mgelfl
Apr 14, 2006 01:48 PM
sfox555
Feb 2, 2006 07:42 PM
