-   Headers, Intake, & Exhaust (https://www.hondaaccordforum.com/forum/headers-intake-exhaust-12/)
-   -   cold air intake install (https://www.hondaaccordforum.com/forum/headers-intake-exhaust-12/cold-air-intake-install-38371/)
SleezyE19 Feb 24, 2011 11:50 AM
im installing a cold air intake and there is another air box below the tube to the throttle body. i took it out and blocked off one of the vacuum lines. the car run but need to know if this is ok. please help i have a 96 accord couple with header back exhaust and now a cold air intake
UrbanEngineer May 24, 2011 11:22 AM
I'm not really sure what exactly you are asking here, but you should probably block off that vacuum line with a simple breather filter rather than just blocking it off. Thats the best I can do to try and help.
g22cd5 May 26, 2011 07:18 AM
take a pic of the hose you are talking about. Now if it's the hose coming off the crank case (valve cover) You need to plug that one onto the nipple on your intake. DOn't put a breather on that I donnno why ppl keep saying and doing that. It's bad for your crank case. The purpose for the hose so all the extra fumes that don't get burnt off escape to the crank case and need to be vented UNDER VACUME. That’s why that line is plugged into the intake b/c the intake acts as a vacuum.
grocerygettertuner97 Jun 16, 2011 12:59 AM
you could probably cap it off with a breather that would work better
g22cd5 Jun 19, 2011 08:02 AM
breathers are worthless bro....if it's a vac. line it needs to be under vac. press. They did that for a reason
Peli Jun 21, 2011 01:05 PM
For my intake install I had to cap this tube that, if I remember correctly, I traced back to the EGR:
http://img809.imageshack.us/img809/1095/cappedegr.jpg
But that was the only issue I ran into. Was told by 2 mechanics that I shouldn't run into any trouble capping it, and in the 1,500 miles since I did I haven't had any issues. This is on a '95 Accord EX, so I believe it's a similar engine layout. I'd like to see a picture of the tube you're talking about as well, because I didn't run into any other tubes that had nowhere to go in the new intake.
Here's the vacuum diagram for my car, you should look up the one for yours and/or take it to a local mechanic you trust to get their opinion on it. That's what I do every time I have doubts about something I'm about to change on my engine. Better safe than sorry.
http://arrc.epnet.com/autoapp/8680/c.../86804486L.gif
