Fuel Injectors for K24
Old Jun 4, 2009 | 09:21 AM
Krysis's Avatar
Thumbs up Fuel Injectors for K24
I have a 2007 Accord with a K24 iVTEC motor. I'm about to get a Morgan RAcing Catback and a Hybrid Turbo for a 8-9psi boost. Does anyone have suggestions for a good fuel injection kit?
Old Jun 4, 2009 | 10:08 AM
finch13's Avatar
Probably won't need one...
But there are quite a few options, a lot of people start out with DSM (Mitsubishi) 450cc injectors. You need engine management to tune injector timing and lower the pulses down.... have you considered that in the turbo build?
Old Jun 4, 2009 | 12:29 PM
03Sleeper's Avatar
Yeah, what is your turbo build? T3/T4?
Old Jun 4, 2009 | 08:11 PM
Krysis's Avatar
yea its actually just t3/t4 mix
Old Jun 4, 2009 | 08:17 PM
finch13's Avatar
I don't think you'll max out the injectors duty cycle at 9 psi. What are you using for engine management? Once you get everything installed and get it tuned, your tuner will tell you what needs to be done.
Old Jun 5, 2009 | 08:24 AM
Krysis's Avatar
I'm going to get a hondata flash and tuning from a custom shop near me.
Old Jun 8, 2009 | 04:46 PM
draser's Avatar
Agree with finch, I'd let the tuner shop take it from here. They should be able to tell if you're lean or stoi. Keep in mind that larger injectors may have lower response time as well.
Old Jun 8, 2009 | 05:01 PM
Hondata does not work with the accord ECU, so you will need the RSX-S or civic SI harness and ECU.
Old Jun 24, 2009 | 02:35 PM
ashiq2009
Default Fuel Injectors for K24
These injectors fit - both the K20 and the K24 engine.
Prices is for a flow-balanced set of 4 injectors and connectors (not pictured)
Our K20/K24 injectors feature all of the following...
Manufactured using only new Denso housings and coils
Connectors included at no extra charge
Flow rates and set balancing in-house by DeatschWerks
All required o-rings, and seals are included
Flow balanced to within 1-2% to yeild higher and safer power
Custom flow report with every set
12-month comprehensive warranty
fortyfootelf
Jan 22, 2010 07:15 PM
Deatschwerks
Nov 6, 2007 03:38 PM
freakrz
Aug 29, 2007 02:08 PM
falkore24
Aug 22, 2007 06:07 PM
brownstreak
Jun 29, 2007 08:22 AM
