is intake worth it
Old Jan 27, 2010 | 07:28 PM
ganchoivanov's Avatar
Post is intake worth it
I have a 94 accord LX 2.2 with 220 000 miles on it and im thinking about putting a cold air intake on it but i am wondering if it is worth it because the engine has so many miles on it.
Old Jan 27, 2010 | 11:18 PM
riverman's Avatar
i think it would. The better air to fuel mix you have better gas mileage. And with how many miles you have you could see better performance and mpg.
Old Jan 28, 2010 | 10:44 AM
g22cd5's Avatar
Supper Moderator
Yes get one it will help out. If something happens to the engine the intake is made to fit in the engine bay. So it will fit any swap you drop in your accord...humm I take that back I think if you swap a k24 in there the intake won’t work with that engine b/c k series sit backwards in the engine bay compared to H/F series engines. But if you have the cash for a k swap you have the cash to buy a new intake when the time comes.
Old Jan 31, 2010 | 09:39 AM
Yeah, i agree- it is only going to help. So I'll probably get one. Thanks guys
Old Jan 31, 2010 | 10:28 AM
Talking Hi Member
Check out our sponsor above for a typhoon kit for your car..
K & N has cold air intakes..having one on your car will make you want to be a street racer tho..you'll get into the sound it makes
click the image !
Old Feb 3, 2010 | 07:42 AM
g22cd5's Avatar
Supper Moderator
thats a nice lookin intake
Old Feb 4, 2010 | 01:22 AM
19Accord97
Go for it!
Just get a sri if you are worried about hydrolock. Your mpg WILL increase by about 1 mpg, but it will more than likely decrease when you first install it and bury the gas pedal to hear the roar of the intake!
Old Feb 4, 2010 | 02:33 AM
Exclamation
Go for it!
That's for sure about getting your foot into the pedal to hear it..every oney seems to do that for a good while..I know I did myself...
WheelbrokerAng
Old Feb 12, 2010 | 09:24 AM
97F22B2's Avatar
you are helping your engine breath with an intake system, so really miles shouldn't be a factor, if anything an intake system would lengthen the life of your engine, unless of course you plan on revving it hard to hear the intake.
Old Feb 15, 2010 | 02:43 PM
overheated's Avatar
The amount of miles on the engine doesn't matter. When's the last time you replaced your stock filter? If anything, look into getting a drop in K&N filter. Also, where are you located (state-wise)? Some states have strict emissions and you can only run CARB DOT approved engine modifications (such as AEM)
Also, you will not gain any power from this (1-2 HP max at WOT)
