my AEM V2 hits side of my car when shifts
Old Jan 6, 2008 | 06:23 PM
Yorty's Avatar
Default my AEM V2 hits side of my car when shifts
when i floor it...shifting into 3rd, 4th or 5th my intake sounds like its hitting the side of my car. Like when my engine rocks it hits and makes a loud noise, sometimes sounding like a gun shot. I thoguht it was the filter or something but its my intake getting loose and hitting. When i tighten it, over time it just getts loose. Are their any way to push something in between the intake and whatever it is hitting?
Old Jan 6, 2008 | 06:52 PM
j_man_honda's Avatar
Default RE: my AEM V2 hits side of my car when shifts
What is ithitting?? Is the tube hitting the sides of that hole where it goes down into the bumper?? If so just put some rubber trim around it
Old Jan 6, 2008 | 07:11 PM
02BlueAccord's Avatar
or u can put some zip ties around it the hold it in place. doesnt look as clean but it works
Old Jan 6, 2008 | 09:10 PM
Yorty's Avatar
It is hitting like the side frame, yea. For some reason the screw down at the bottom near the filter always gets loose and moves a ton.
Old Jan 7, 2008 | 10:33 PM
GT03 TJS's Avatar
blue locktight FTW!
Old Jan 8, 2008 | 03:24 AM
i didnt even think about locktight lol
Old Jan 8, 2008 | 04:47 AM
Joseph's Avatar
it sounds like a shot gun [:-]!?
Old Jan 8, 2008 | 09:16 AM
klrspz's Avatar
yeah lock-tite or a locking nut... pretty standard stuff when trying to keep stuff tight
Old Jan 8, 2008 | 11:54 AM
klrspz's Avatar
I also wanted to mention, that my CAI came with am ount kit that consisted of a rubber spacer.. if you compress that rubber enough (not too much, don't want it to split once it starts to dry and rot) it'll act as a temporary replacement for a lock-washer.. i say temporary because we all know rubber deteriorates.
Old Jan 8, 2008 | 03:07 PM
sir_nasty's Avatar
if it's the sheet metal where the intake goes through that's getting hit then put some loctite on the bolt that keeps loosening, then get a lenghth of hose, carefully slice down the center of it on one side then simply slide the hose on over the sheet metal, glue it in place if you want some added safety...
