Performance questions
Afternoon fellas, I bought a 2012 Honda Accord EX sport coupe with a 2.4 l dual overhead cam VTEC and five speed. Just have some questions about why when I shift I can't shift quickly but it shifts fine otherwise and what kind of performance mods and tunes are good for a budget.
Originally Posted by Hondacivic33
(Post 392942)
As for modifications; you have three options:
Originally Posted by shipo
(Post 392943)
Are you having an issue with the speed of the gear change itself or the speed of the clutch engagement?
The K&N, MSD Coils, and E3 plugs are all snake oil; I strongly recommend you return those bits to stock. As for the shifting, is it only when the transmission is cold, or once it is well warmed up as well?
FWIW, for Honda's 6-Speed manuals, the go-to MTF is ACDelco Synchromesh Friction Modified (part number 10-4014); this stuff cured a multitude of issues across the lineup of Honda and Acura transmissions. |
(Post 392942)
I'd run the Redline MTL/MT90 transmission fluid and a 0w30 from Redline,Amsoil or Mobil 1. A quality intake SRI from aem or injen. Recommend the non oil filters as their filtering is better. Would get a Apexi car back exhaust and header. Would do the front strut bar and rear sway bar. |
It does have upgraded sway bars, coilovers and Camber kits on it. I like I said before it does have a k&N ram jet intake which came with it I wouldn't purchase it but it's on there I was wondering about the Hondadata programmer?
