so ive heard headers intake and exhaust is a waste of time unless?
Old Oct 20, 2015 | 02:11 AM
gordito's Avatar
Default so ive heard headers intake and exhaust is a waste of time unless?
You increase compression.....I have a 95 accord sohc vtec.. Would upgrading my Throttle body and fuel injectors help so the car would use the intake more efficient for the exhaust upgrade? I have basic knowledge of the car I've put coilovers entire exuast and intake have done all major services besides timing belt bye myself. So I can use tools but deff don't really know what I'm doing and I really like my car just would like to make a little faster..
Old Oct 20, 2015 | 08:44 AM
joselito7's Avatar
Intake and exhaust are not a waste of time. Many will want to argue, I always state try it for yourself then talk all you want. Now my suggestion would be to upgrade youre coil and then save up for a proper aftermarket computer and pay for a tune. Then all these small but important upgrades can be maximized. Again not looking for an argument, I know these things to work, headers , exhaust, suspension and tune but it don't come cheap, but definitely cheaper than a V6 all day long.
Old Oct 20, 2015 | 09:22 AM
gordito's Avatar
Coil? My car has a distributor with a rotor so do you mean upgrading that.. Also if I buy a computer to tune it I have to take it to a shop for dat or is it pretty easy to diy..and any recommendations on what kind and were to get one thank you for da reply by DA way
Old May 17, 2016 | 08:20 AM
Half-fast's Avatar
I am late to the party I know, but life is busy sometimes.
My car has a 2.4 intake, Bisi level 2 cam, Hondata s300 and headers. Dynoed at 158 at the wheels. Compression is less of a factor I think, it's the custom tune that makes it all come together.
Old May 18, 2016 | 02:36 PM
Another way to look at it - it's hard to make a blanket statement like that. An intake (for example) can only improve things to the extent that the stock intake is causing restriction. Many Hondas have intake & exhaust that are sorta not-very restrictive to begin with (that's a pretty vague statement).
Some big old domestic car from 30 years ago might have a very restrictive intake system. In that case, a low-restriction intake can make a dramatic improvement.
Same kind of story for the exhaust system.
Old May 18, 2016 | 02:57 PM
shipo's Avatar
The only real differences adding an intake and exhaust will make are as follows:
  • Thinner wallet
  • More noise
  • Usually a loss in mid-range torque
  • Usually a slight bump in power at wide open throttle up near redline
  • Bragging rights along the lines of adding 22" wheels to your car
Old May 25, 2016 | 07:25 PM
woody31's Avatar
Almost A Senior Member
The only thing I have done to mine is a drop in K/N air filter,,and Borla exhaust,,it is plenty fast to get a ticket so Im skipping the hedder and cold air(loose term) kit,,which usually brings in hot underhood air anyways,,
If i want to go fast I jump in my Dodge SSV truck,,,
X2 on the above comments by Shipo...
jenny
Aug 12, 2015 07:23 PM
tobybul
Dec 17, 2013 02:53 PM
Jul 21, 2012 09:26 AM
scansbar
May 18, 2009 03:24 AM
