whats next
Old Oct 26, 2007 | 11:37 AM
streetcustoms's Avatar
Default whats next
so i got a aem short ram cold air intake and a magnaflow cat back exhaust for my 2001 accord ex automatic l4 with about 91k miles on it and was wondering what can i do next to it i hade read that spark plug wires and pulleys add hp or sould i get headers i need your help guys
also is it worth geting slotted rotors and 18s for an accord
Old Oct 26, 2007 | 12:16 PM
Fenix's Avatar
Default RE: whats next
As far as stopping power goes, the stock brakes work great. Theres no real need to do it because youve got bigger rims. Astheticly i say def do it. I did it to my friends 300C a few weekends ago and it looks amazing, and hes got 22's. The most important thing to do is bed(spelling?)the brakes or you'll end up in a pretty serious accident.
Headers rob low end tourque but makeup for it in the top end. so if your willing to make that sacrifice then go for it. Plugs/wires/pullys im not sure about, youll have to wait for someone else to make that call.
Old Oct 26, 2007 | 12:24 PM
sir_nasty's Avatar
plugs and wires aren't going to add power but they'll improve throttle response. Pulley's don't "add" power either they just free it up. What I mean is that when you put them on they are less weight and less drag on the drive system so you get more power to the wheels. If you get undderive pulley's it will just put less power to the a/c, alternator, p/s etc. and free up even more HP.
Old Oct 26, 2007 | 12:31 PM
underdrive pullys do u mean the ones on the engine so to change dos the engine has to come out right?
or is it the alternator pulleys
Old Oct 26, 2007 | 12:57 PM
sir_nasty's Avatar
it's the accessory and crank pulley's so the motor doesn't have to come out.
Old Oct 26, 2007 | 01:01 PM
00AccordLX5spd's Avatar
Registered User
The engine does not have to come out to do the pulleys.
If you live in a hot climate like I do I would not recommend underdrive pulleys cause your a/c won't blow as cold.
Stock plugs (NGK PZFR5F-11) and stock plug wires (Sumomito) perform the best of anything available. The stock plugs in the 2000 and newer models were double platinum and they recommend changing them every 100k miles. Plug wires-I would only change if they are damaged, but that is all a matter of opinion.
Old Oct 26, 2007 | 01:03 PM
Registered User
Good luck with the crank pulley bolt if you change that one[sm=smiley5.gif]
Old Oct 26, 2007 | 01:14 PM
well if ig et it im gonna get a shop 2 do it for me lol
and is their a site were i can find like the complete set to buy it the alternator then underdrive one
Old Oct 26, 2007 | 01:25 PM
sir_nasty's Avatar
www.unorthodoxracing.com or www.aem.com or ebay for those two brands
Old Oct 26, 2007 | 04:00 PM
i am most likely going to order aem power pulleys this weekend hoq hard is it to install it on a scale of 1 to 5 5 being the hardest
