Who wants the nipple?
Old Jun 19, 2008 | 05:34 PM
falkore24's Avatar
Default RE: Who wants the nipple?
no EGR = worse MPG
At idle, EGR mixes exhaust gas so less fuel can be used and still result in a good AF mixture. Exhaust gas has very little O2 left in it to change the mixture. Less fresh air = less fresh fuel.
Old Jun 19, 2008 | 07:22 PM
gojuice
ORIGINAL: falkore24
no EGR = worse MPG
So to keep the A/F ratio up the computer would have to dump more fuel in which may give you a more efficient burn with a detriment to MPG's?
Old Jun 19, 2008 | 07:26 PM
gojuice
So, Hobbin, did you make any changes...hows this situation progressing?
Old Jun 20, 2008 | 08:46 AM
falkore24's Avatar
ORIGINAL: gojuice
ORIGINAL: falkore24
no EGR = worse MPG
If I understand correctly, you are asking about the situation with the EGR blocked off. In this case, the engine will require more fuel for a good AF mixture because there is more fresh air comming in and thus more O2.
Old Jun 20, 2008 | 12:12 PM
ford's Avatar
so then it would definitly lessen the mpg of the car?is my understanding right?
Old Jun 20, 2008 | 01:16 PM
gojuice
ORIGINAL: ford
and most likely raise cumbustion temp, a lot in some cases...
Old Jun 20, 2008 | 10:29 PM
  #17
ford's Avatar
ok..so if i were to buy a intake system, i should find one that has 2 nipples then right?? so that both of the original hoses goes to the intake system again...
Old Jun 22, 2008 | 01:38 AM
  #18
Codonah's Avatar
Bottom line: Hobbin and ford...both your 94s just need that "red" hose to be plugged. The aftermarket intake system only requires that the "blue" hose be connected to the nipple. Cutting and plugging that "red" hose is perfectly safe. So thus, the aftermarket intake system only has one nipple. Keep in mind the manufacturers (AEM, K&N, etc.) knew what they were doing when creating these intake systems.
Old Jun 22, 2008 | 12:50 PM
  #19
klrspz's Avatar
Here's my intake. It's an eBay special, had to slightly modify for the sensor; but no MAF.
CAI01.jpg?t=1214156884
You can see my connections easily
It's probably me, but I can't make heads or tails of your pictures.
Old Jun 23, 2008 | 09:16 AM
  #20
falkore24's Avatar
ORIGINAL: Codonah
If this is in fact the case, this step would be included in the installation instructions and the kit would include the plug. All hoses should be accounted for in the installation of any intake.
