2007 heat broken
Yesterday my heat,ac and blower suddenly stopped working . My dash is dark and the outside temp indicator is not displaying (guessing its related somehow) Looking for suggestions on diagnostics to do and possible dyi fixes thanks |
Where you working on something that caused it? Disconnect the battery for 15 mins then reconnect. Check fuses 21, 23, 30 in the cabin fuse box located by the drivers left
2007 heat broken
Thanks for the recommended fix - I wasn’t working on the car - the heat worked earlier in the day and then just stopped when I went to use later . |
Originally Posted by Donna Bailey
(Post 383381)
2007 Accord heat broken- new information
I wanted to add that besides my heater being broken, not showing up on my dash - the radio shows up but the defrost, heat and AC indicator does not show up. My seater heaters do not work and the light does not work The outside temp usually shows up on my dash - now it reads —— Hoping this additional info helps |
Originally Posted by Seanjordan20
(Post 383382)
It was an interior fuse - fixed
Glad you found it but the question is what blew the fuse? They don't blow just becasue, something happened or isn't "right" which cause the fuse to blow.
Which one was it? |
