2007 heat broken
Old Dec 9, 2018 | 06:46 PM
Donna Bailey's Avatar
Default 2007 heat broken
Yesterday my heat,ac and blower suddenly stopped working . My dash is dark and the outside temp indicator is not displaying (guessing its related somehow)
Looking for suggestions on diagnostics to do and possible dyi fixes
thanks
Old Dec 9, 2018 | 07:03 PM
Seanjordan20's Avatar
Where you working on something that caused it? Disconnect the battery for 15 mins then reconnect. Check fuses 21, 23, 30 in the cabin fuse box located by the drivers left
Old Dec 9, 2018 | 07:24 PM
Thanks for the recommended fix - I wasn’t working on the car - the heat worked earlier in the day and then just stopped when I went to use later .
Old Dec 10, 2018 | 07:28 PM
The Toecutter's Avatar
thanks
Welcome. It might be worth having a look in the Audio/Visual form in the General forums, as someone might have had a similar problem.
Old Dec 11, 2018 | 07:48 PM
Default 2007 Accord heat broken- new information
I wanted to add that besides my heater being broken, not showing up on my dash - the radio shows up but the defrost, heat and AC indicator does not show up.
My seater heaters do not work and the light does not work
The outside temp usually shows up on my dash - now it reads ——
Hoping this additional info helps
Old Dec 15, 2018 | 06:42 AM
^ x2. I agree and would start with checking the fuse(s).
Old Dec 15, 2018 | 09:59 AM
It was an interior fuse - fixed
Old Dec 16, 2018 | 10:45 AM
Glad you found it but the question is what blew the fuse? They don't blow just becasue, something happened or isn't "right" which cause the fuse to blow.
Which one was it?
p.p.cartier
Oct 1, 2017 06:51 PM
rick_esco
Oct 26, 2014 06:28 PM
skijour
Aug 15, 2012 08:31 PM
Cessna172
Nov 5, 2010 01:22 PM
pgopalak
Dec 17, 2004 03:30 PM
