91 honda wagon (automatic) keeps dying on me.
i had recently replaced the transmission control unit in the car because is was not shifting past 3rd gear when i would drive on the freeway and would even jerk back and forth like the gas pedal was being pressed and let up. So from looking at forums i figured it was the tcu and ordered one from eBay with the exact code and changed it out. Car was working fine after that until the other day when i was driving it to work i noticed the speedometer start twitching then it dropped to zero right after that the rpm gauge did the same thing then the car started jerking back and forth like i was running out of gas or something and eventually died on me when i slowed down. does anyone know what this could be?
It could be a lot of things.
no spark in the cylinder. - dead battery - bad battery connections -bad ecu no fuel in the cylinder. - out of gas -clogged fuel filter - bad fuel pump - damaged fuel line no air in the cylinder. -bad intake -ecu not sending signal -bad motor on the throttle body. or a myriad of other things. |
