95 accord
Old Aug 19, 2016 | 07:23 PM
donnieg's Avatar
Default 95 accord
I have 95 honda accord ex did tune up pcv valve rotor cap dist cap plug wires and i put e3 plugs ran royal purple fuel treatment and half way through tank started to idle rough and running rich. After about 20 min of running but if i shut off let it sit 5 min it will start running fine then after a few minutes it will start running rough again
Old Aug 25, 2016 | 11:06 AM
Check engine light? What codes?
Old Aug 25, 2016 | 11:09 AM
donnieg's Avatar
No check engine code just srs code
Old Aug 25, 2016 | 03:07 PM
Running smooth on cold start, and warmed begins to miss suggests a possible fuel mixture problem. This will usually set a code for lean or rich condition.
An advanced scanner w/ data monitoring is necessary to explore fuel trims and perhaps a clue to problem.
Make sure spark plug wires are routed correctly.
Old Aug 25, 2016 | 03:50 PM
If the plug wires were crossed it would run horribly at all times right from the start.
