f22b2 to f23a4 swap help
i have a 95 accord lx 4 cylinder. im thinking about getting an engine swap to a f23a4 because my crank shaft seized up. i know it should be a fairly easy install, but will i need a new ecu, and are they the same obd? or anything els i should be aware of? thanks
Welcome to HAF.
Do some searching, there are a few members that have done this......I even think "Roader" has a high level write up in the DIY Section about this.
They are not the same OBD - your 95 is OBD-I and the F23 are OBD-II. I would stay OBD-I.....meaning there are some sensors on the F23 that you will not use.
Isaac Bray
08-23-2013 05:58 PM
