Front bumper help
Probably a can of spray paint. If you can't find your color at the Zone or O'Reilly's in pre-mixed cans, you could try having it custom mixed and put into a spray can by an auto body paint supplier. Some NAPA's, Advanced Auto and others do this too, you just have to see if they custom mix paint first.
I hope this helps.
I hope this helps.
- The bumper lip spoiler can be replaced or just removed without replacement. It is held on with plastic clips. Honda Part No.: 71110-TA0-A00, list price $18.73. Local dealers may mark up over list price. Internet dealers usually is less than list; but, charge shipping. Honda e-store allows for ordering on-line and free pick-up at local dealer; however, not all dealers provide discount on e-store. (Due to so much of the lip spoiler being painted, paint solvent may not remove it and leave it looking good.)
- The two side pieces are part of the inner plastic fenders. They can be removed; however, they appear to be held on with rivets. These pieces are not separately sold, they are sold as part of the inner plastic fenders. (Since there is not as much paint/paint over-spray on these two pieces, you can try solvent. Although 3M adhesive remover is marketed for adhesive removal, it is a safe solvent which I have also used to remove small amount of uncured or properly finished paint. -- You can try other types of remover such as Goof-Off.)
If the paint remover works well, maybe use that for the lip?
Another alternative might be some kind of black paint that's made for bumpers or other plastic parts (the paint has to be a little flexible because that lip is a little flexible).
That would be my suggestion as well. I didn't realize someone painted those parts body color, which means it's been replaced. If you decide to try and remove the paint, use a "scuff" pad soaked in your chemical solution of your choice, as that will help remove it, and it will give the base material some "tooth" for some black paint to adhere to. Just a thought. Also, I couldn't get the pic to blow up like redbull-1 did.
deathman68
May 8, 2006 05:01 AM
