HELP!!!!
Old Dec 4, 2007 | 06:01 AM
mark1975
Default HELP!!!!
I need an ABS Modulator for my 1999 Honda Accord. The dealership wants £1300 for one, I cant afford that, does anyone know where I could get a reconditioned one or maybe they have one in their shed!?!?!?
Old Dec 4, 2007 | 08:32 AM
Default RE: HELP!!!!
1300 pounds? I bet you're not in the USA...
You might have to be careful about differences betweenUK & USA spec cars. I don't know if the modulator is exactly the same.
Old Dec 4, 2007 | 08:37 AM
deserthonda's Avatar
what is the problem with it ///? is it leaking ??
Old Dec 4, 2007 | 08:48 AM
falkore24's Avatar
Hello new member!!!! Welcome to the "New Member Area" where introductions are made and questions don't belong. For the future, please put your car info in the signature section of your profile and check the "add signature" box when making posts. This helps us to help you. Also, you will get a lot more responses if you post questions in the correct sections ..... although there is no "Brake" section, this would fit best under "General Tech Help".
Again, welcome to HAF!
Also, as the 6th gen accords get trashed for failed trannies, you should be able to find other parts like the modulator that you are looking for.
Old Dec 4, 2007 | 09:31 AM
00AccordLX5spd's Avatar
Registered User
If I were you, I would just drive it without ABS!
But seriously, if you want to fix it, answer deserthonda.He's your man. Is it leaking? Why does it need to be replaced?
Old Dec 4, 2007 | 09:32 AM
Registered User
ORIGINAL: falkore24
Calm down. Don't make meget the hose!
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
