Windows/key problem
Old 12-23-2016, 12:48 AM
rennat's Avatar
Default Windows/key problem
Windows open when using key. Is this normal on 2017 accord?
Old 12-23-2016, 09:23 AM
Prospector's Avatar
We need more information to understand the issue. When you say, "key", do you mean the fob? Your Accord does have key-less entry, right?
Old 12-23-2016, 04:52 PM
rennat's Avatar
The fob has a key also. I used to key to open the door as a test. The windows rolled down and the sunroof opened. I had to start the car to close them. Is this normal?
Old 12-23-2016, 05:54 PM
It is a normal feature on certain models. Even older generation Accords (e.g., EX trim, etc.) had this feature.
If you don't hold the key in the unlock direction, it will not open the windows and moonroof. To unlock the doors only, just turn the key and release (letting it return to the central position).
You can use the key to close the windows and the moonroof too.
Attached Thumbnails Windows/key problem-key.jpg
csh217
06-17-2014 05:53 PM
corlyf
09-12-2012 11:30 PM
puresoundz
04-13-2009 10:30 AM
th22ek9
09-13-2006 11:11 PM
th22ek9
09-08-2006 09:07 PM
Quick Reply: Windows/key problem
