my 96 Accord
Got my accord in Dec 2013. First thing i had to do was oil change, very thick. Next thing was replace the radiator, rusted out. Replaced driver power window motor. Replaced timing belt and water pump at around 101,000. Recently changed both front stabilizers. Also needed to replace shift cable. The next replacement is the flex pipe and maybe the cat due to rust. Definitely need new speakers!
Purchased mine from a man who purchased it at an auto auction around Pittsburgh,Pa. Cleaning up car I found a drivers license of a woman from the state of California.
My Accord is dark green with a grey cloth interior with a four cylinder auto transmission and a/c.
Welcome to the HAF...
Thank You for joining the HAF..bunch of good members in here.
Went to change my spark plugs and found oil in the plug hole. Now i need to change valve cover gasket. I'm told that this will cause miss fires if I don't fix.
Looked on you tube and it looks fairly easy as a do it yourself thing.
I will try to get photos on eventually.
