New From Maine
Old Dec 27, 2011 | 05:10 PM
Russianred's Avatar
Arrow New From Maine
Hey guys,
New to the forum, kinda, but not new to Accords OR forums .
Looking forward to learning a lot here, and helping out as much as I can! I also have some parts for 98-02 Accords so if anyone needs something just let me know.
Here's a pic of my ride to start:
My name is Nikita, I'm a guy, I am Russian. See you on here!
Old Dec 28, 2011 | 09:29 AM
Здравствуйте Никита!
I take Russian in school, but I'm sure I know nothing compared to you!
Welcome to the forums, your accord looks good. You should post some specs on what you have going on under the hood.
Old Dec 28, 2011 | 11:02 AM
Russianred's Avatar
Arrow
Hey man, thoroughly impressed by you speaking/writing a little Russian! If you ever have questions or want to learn some stuff they won't teach you in class haha, you know who to hit up. I notice you live in this neck of the woods too - New Hampshire, not too far. Here's an underhood pic for you guys:
Here's just a little bit of what's going on, though some stuff I have changed or upgraded since this pic was taken:
Engine/Performance:
+ ARP Head Studs
+ Resurfaced and Pressure / Vacuum Tested Head
+ Dark Emerald Pearl Custom Painted Valve Cover
+ OBX Racing Spark Plug Wires
+ Helix Power Tower Throttle Body Spacer
+ NGK V-Power 2-Step Colder Copper Plugs
+ NRG Polished Engine Torque Damper
+ Centerforce DualFriction Clutch Kit
+ Fidanza 8lb. Lightweight Aluminum Racing Flywheel
+ PSPEC True Shortshifter
+ MOMO Competition Weighted Shift ****
+ Nokya Racing Pedals
+ OEM V6 Accord Hood Dampers
+ Custom 3/4" Hood Spacers
+ Custom Engine Grounding Kit
+ Only Mobil 1 Synthetic Oil
+ Odyssey PC680 Drycell Small Battery
==>Turbo:<==
+ Turbonetics T-15396, T3/T04E, 57 Trim, 0.63 AR, 5-Bolt Exhaust Side Flange
+ Custom Ported & Blended Cast Iron Log-Type Manifold
+ Custom Exhaust: 2.5" Downpipe To 2.75" Flexpipe To 3" Straight Pipe Back To 3" Magnaflow Muffler & Tip.
+ DRAG Intercooler & Piping
+ Clampco T-bolt Clamps
+ Injen Intake Cone Filter With Short Ram Extension
+ Tial 38mm Wastegate
+ Blitz Dual Drive Blow-off Valve
+ Custom Fabricated Dump Tube
+ Golden Eagle Vacuum Manifold
+ Tapped Engine Block for Oil Feed & Oil Pressure Gauge Lines
+ Tapped Oil Pan
+ Walbro 255lph Fuel Pump
+ AEM EMS Series 1 Standalone ECU
+ Denso 480cc Injectors (Flowmatched, Flowtested by Deatschwerks in Oklahoma City)
+ DSM Low Impedance Resistor Box
+ OBD1 IACV, With 2-Wire Plug, and Blacktraxx Blockoff Mounting Plate
+ Megan Racing Fuel Pressure Regulator
+ Gauge Cluster Dual Pod
+ Autometer Pro-Comp Boost Gauge
+ Greddy Electronic Oil Pressure Gauge
+ Greddy Profec B Spec II Electronic Boost Controller
+ AEM UEGO 6-in-1 Wideband Controller
+ Apexi Black Pen-Type Turbo Timer
I'll post up a complete member's ride thread a bit later when I have time. Enjoy!
- Nikita
Old Dec 28, 2011 | 02:23 PM
Talking
Good posts and pictures Nikita..Glad to have you with us here in the HAF...
Old Dec 28, 2011 | 03:45 PM
Looking good, any idea how much power you are making.
Looks like you might want to consider relocating your battery to the trunk.
Old Dec 28, 2011 | 04:36 PM
Russianred's Avatar
Arrow
Yeah, definitely battery relocation is a priority which I will be doing!
I was base dyno'ed at 120whp and at 6.7psi of boost I made 214whp/223wtq
I will start a Ride & Build thread maybe tonight, in the Nitrous, Super Chargers, & Turbos section!
Also, what's your name if you don't mind me asking, and how do I make it so I have a signature picture appear, and an avatar present? Do I need a certain amount of posts, or do I just go and edit the options?
TIA.
- Nikita
Old Dec 28, 2011 | 08:26 PM
Not bad, had a chance to run it at a dragway?
My name is Cameron.
Signature picture you just need to embed a picture. Avatar I am not sure, you should be able to do it from where you set up your profile, but I know it wasn't working I'm not sure if it has been fixed.
Old Nov 8, 2021 | 10:55 PM
SovietKidd's Avatar
Default Hood spacers
Hey I See that you have hood spacers do you know which ones would work on my 2017?
Old Nov 9, 2021 | 07:41 AM
Russianred's Avatar
Arrow
Hey man, I don't know any exact specs because I used shaft collar spacers, I would say 4 of them, they are about an inch tall each. Hope this helps!
Old Nov 9, 2021 | 10:53 AM
SovietKidd's Avatar
Amazon Amazon
something like the above will work yes? they don't make specific ones for the accord
