Is this all u need for a turbo
Is this allyou need to make a turbo system
is there anything missing please help.... Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid) Spearco Intercooler System Powder-Coated Intercooler Piping Silicone Hose / T-Bolt Clamps Exhaust Manifold - high carbon cast-steel with ceramic coating Fuel / Timing Controller (electronic fuel / timing management system) Fuel Injectors Wastegate Assembly By Pass / Blow Off Valve Assembly Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge Intake System with Air Filter |
RE: Is this all u need for a turbo
dont forget the most important part
engine management |
look for a list of things which i wrote down a few months ago... something like, " f23 turbo " or something similar
Aight e-management..
gotcha on that.... I have read alot of your post kevin how u put everything on... im just double checking that is all.... |
Where'd you copy and paste that list from.
oil and coolant lines for the turbo
I copied and pasted from a page that a member posted up i believe this it
http://www.tasauto.com/Product/Brows...=755&sz=50 The turbo is a lil too too expensive butI just want to know what else might I need besides all this all i posted... they just specialize on hondas so i think its a good page... oil and coolant lines aight check on that.... e-magament oil and coolant lines Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid) Spearco Intercooler System Powder-Coated Intercooler Piping Silicone Hose / T-Bolt Clamps Exhaust Manifold - high carbon cast-steel with ceramic coating Fuel / Timing Controller (electronic fuel / timing management system) Fuel Injectors Wastegate Assembly By Pass / Blow Off Valve Assembly Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge Intake System with Air Filter |
Don't buy a kit - especially not from there or at all.
Start searching and reading, you're gonna need it. |
ORIGINAL: pawel oil and coolant lines for the turbo |
Why not buy it from there i wasn't planning to its way too much for my pocket...hahaha
yea i don't plan on buying a kit just make one out of scratch... Yea i been doing that homework reading and searching... But what is the main things im gonna need to know and learn about the turbo. |
