Can i Turbo?????
Old Jun 21, 2007 | 10:01 PM
03Sleeper's Avatar
Default RE: Can i Turbo?????
Get a smaller turbo if you have an AT.
Pros:
-Basically no turbo lag
Old Jun 22, 2007 | 08:16 AM
02accV6
lol they have different sizes in turbos? [:-]kevnaccord thats a good idea....how would i know what size turbo is good?
Old Jun 23, 2007 | 08:31 PM
KevinAccord's Avatar
well, i went for a t3/t4 hybrid, which means that the cold air turbine (to the intake)is t4 and the hot air turbine (exaust) is t3, which makes it load faster. that's anice size....not big, neither small, just perfect! oh, and buy the stuff on ebay..... for a list of what u need go here: https://www.hondaaccordforum.com/nee...m_55077/tm.htm and look for my post w/ the list of things i bought... it will be a little different for u, but the stuff should be about the same........
i listed most of the stuff i bought. the onlythings missing are the new fuel pump from walbro and the fuel rail. u will also need an MSD BTM which controls the timing of the car, since it will be boosted, it needs tolower some degrees.
Well, good luck!
Old Jun 24, 2007 | 02:31 PM
BlkCurrantKord's Avatar
Kevin - you dont need a fuel rail and that MSD BTM doesn't work on our cars.
Old Jun 24, 2007 | 02:53 PM
03Sleeper's Avatar
fuel rails are cool though...kinda like the strut bar...wont hurt to have it.
Old Jun 24, 2007 | 05:11 PM
Yea cause you should just buy it b/c its cool. Don't worry about the fact that the stock fuel rail is good to around 300hp, in fact, there's guys making over 300hp on the stock fuel rail.
Old Jun 24, 2007 | 10:39 PM
  #17
BlkCurrantKord - Why won't i need that? what do u mean it doesn't work? BTM's are to slow the timing of the car to avoid detonation...that is very helpful when going turbo... is there a specific reason why they don't work? thanks in advance...
Old Jun 25, 2007 | 08:08 AM
  #18
ORIGINAL: KevinAccord
B/c the ECU controls the timing, so unless you have some sort of standalone like AEM EMS or Greddy E-manage, whatever amount of timing you think you're removing, the ECU is putting right back in. Our cars aren't like civics and tegs where we can rotate the distributor toadd or remove some timing. In case you dont believe me, search Honda-Tech or Everything-Honda.com
I know what the BTM is for, my brother has it on his turbo civic for his 15lbs of boost.
Old Jun 25, 2007 | 01:32 PM
  #19
03Sleeper's Avatar
Bleh. I'm up for a basic complete rebuild of the engine.
Old Jun 26, 2007 | 01:59 AM
  #20
so how should i slow te timing then? i have an Apex NEO...will that work?
