can a turbo or spool from an lancer fit on a honda
Old Mar 28, 2008 | 01:46 PM
finch13's Avatar
Default RE: can a turbo or spool from an lancer fit on a honda
Like falkore said, a turbo set up is richer for the reasons listed. The timing (spark) maps are also retarded, or slowed down, a few degrees to account for the higher compression of the air/fuel mixture in the cylinder. You would also do the same fora N/A setup with high compression pistons. The key to retarding the timing is that the mixture is ignited much earlier than the stock 15* BTDC to avoid the possibility of detonation in the engine, where the mixture spontaneous combusts from the high compression.
Old Mar 28, 2008 | 03:19 PM
DA KID RYU's Avatar
wow this is alot of info and kinda hard to comprehand...
for reals...i need to get to the reading guys...thanks.
laymans terms someone...hahaha
Old Apr 28, 2008 | 02:11 PM
KevinAccord's Avatar
just read it calmly and whatever you don't understand... wikipedia... ifstill don't get it,then us again, if still.... then buy yourself a bicycle... j/k! just keep reading and you'll get it...
98accordman
Oct 24, 2010 10:34 PM
Zuerst
Sep 10, 2009 03:26 PM
botang47
Dec 15, 2008 11:37 AM
Dazed
Sep 28, 2007 09:06 PM
abelh7
May 1, 2006 02:28 AM
