F22B1 SOHC VTEC TURBO?!
Old Jul 6, 2008 | 02:07 AM
  #21
ford's Avatar
Default RE: F22B1 SOHC VTEC TURBO?!
if thats the case then i think yours is ok to turbo..i guess just dont pass 8psi?
Old Jul 6, 2008 | 02:29 AM
  #22
importedminds's Avatar
yea atleast not until redoing the internals
Old Jul 6, 2008 | 05:48 PM
  #23
ford's Avatar
yep!!that is correct.. ..
Old Aug 5, 2008 | 11:23 PM
  #24
shaun8484's Avatar
i dont understand why the f22b1 is such a bad motor to boost because the bottom end can hold up to 300 hp stock,and if you can get a better rod to stroke ratio it shold hold up just as good as the next.
Old Aug 6, 2008 | 01:21 PM
  #25
falkore24's Avatar
VTEC off + boost rpm range = compressor stall
Old Aug 6, 2008 | 01:29 PM
  #26
shaun8484's Avatar
so v-tec is not good with boost
Old Aug 6, 2008 | 02:23 PM
  #27
BlkCurrantKord's Avatar
No, its not.
Old Aug 6, 2008 | 02:36 PM
  #28
falkore24's Avatar
Only if you can override it's control to ensure that it is engaged prior to boost .... and that it's not an i-VTEC system. KevinAccord has a V-AFC controller overriding the variable engagement, so his works fine.
Old Aug 6, 2008 | 03:21 PM
  #29
shaun8484's Avatar
so if v-tec is going before you start spooling it will be fine.
Old Aug 6, 2008 | 03:46 PM
  #30
falkore24's Avatar
Depending on the type of VTEC, yes.
