getting the f23 turbo ready
alright everyone, ive posted a thread about engine swaps and havent really gotten any convincing data on that... so might as well go with the next best thing... or first best... whatever the deal is...
i have a f23a1 i was thinking of buying a t3 stage 3 turbo ..... what kind of work do i need to get done to the motor before the initial install???
you can leave the motor stock if you like, nothing that you have to do to it per-say except install the components. If you want to push a lot of bost then you'll want to go to stronger components and a decent fuel managment system
the man the myth the legend himself, hows it going sir_nasty....
what kind of power should i expect from a stock motor with whatever the max recommended boost is ???
i wouldnt want to run the max recommended anyways but just for an FYI...
id prolly only run about 4 or 5psi if thats not pushing it lol.... also would this shorten the life of my f23??
That will be fine. The max boost is 6-8 psi, and I would never go over 6 if it were me. As far as shortening the life of the engine, it simply depends how you drive it. A few runs here and there is ok but all the time and itll be a short ride. I would also switch over to a good synthetic oil.
As long as you don't dog the sh** out of the f23 w/ the turbo, (as many people do when they get a turbo) youll be fine. Even if the f23 does blow, they are relatively cheap these days. How many miles are on your f23 right now??
it has about 132400 miles ....i changed my oil over the weekend to mobile1 5w-30 full synthetic... runs smooth as a whisle....
i understand i even checked the spark plugs (crappy bosh platinums) and they looked ok... but still thinking about changing over to ngk...
