hydrogen injection
RE: hydrogen injection
I went and checked out the website and then googled oxy-hydrogen. Other than a couple of websites saying its tremendously flammable, I don't see why it wouldn't work as they say. My question is, why wouldn't I just make it myself? Plenty of websites teach you how to make them and looking at the parts on the website makes it pretty self explanatory on how to hook it up. Red wire to positive side of batter to one screw post on the generator (although all the websites put the posts on the bottom) black wire to negative side of battery to other screw post. Water and potassium hydroxide (i believe is what I read) in the chamber, screw the top on and voila, put a silicon line that's ****** into the screw top that gets tapped into your intake piping and you're done. I would put an on off switch on the power lines so that it can be turned on/off or just wire it into something that is only on when the car is.
The potassium hydroxide acts an electrolyte allowing the current to flow through the water which decomposes the water into its basic elements, hydrogen and oxygen, thusly you get oxy-hydrogen. I don't know how they do it but the website I found says that it should be dispersed into water so as to not spark inside the generator itself which makes it go BOOM, that wouldn't be so good in your engine bay. Anyways, if anyone else finds out morre about this, let me know. I'm not going to drop 250 bucks on it but if all it takes to make it is 30 dollars in parts, I'm all over that shizzy, just to see what happens. |
Why not just do methanol injection?
because methanol has carbon to convert to co2, a greenhouse gas ..... and water is so much easier to come by.
I'm not sure how the above company does everything in one cylinder unless they aren't doing any of the "lets make sure we're safe" parts. But here is a complete how to, he doesn't give installation instructions but very good visual diagrams to follow. Just follow the link :)
http://peswiki.com/index.php/OS:Joe_...abi%27s_e-Cell On the page is a step by step to build the actual cell, which I couldn't find anywhere else. |
ORIGINAL: falkore24 because methanol has carbon to convert to co2, a greenhouse gas ..... and water is so much easier to come by. http://www.snowperformance.net/index.php |
ORIGINAL: BlkCurrantKord ORIGINAL: falkore24 because methanol has carbon to convert to co2, a greenhouse gas ..... and water is so much easier to come by. http://www.snowperformance.net/index.php |
I think this thread isn't necesarily about more power. The Oxy-Hydrogen assist set-up doesn't add a ton of horse power that I know of, I'm sure it adds some but not much. It's primarily for better mpg and also the fact that its clean. On top of that, water is still WAY easier to get then methanol. Go to your sink, I bet water comes out and not methanol. And if you do it right you stop by the grocery store and get distilled water, I don't know about other grocery stores but mine doesn't sell methanol.
And for diesels, a methanol/propane/water injection makes even more horsepower. Unfortunately, I'm pretty sure that would blowup our hondas. |
You guys amaze me sometimes.
I amaze myself sometimes too http://www.ihateitall.com/forum/imag...ies/juggle.gif
