a little help please...
Old Feb 20, 2007 | 09:11 PM
Boogy's Avatar
Default a little help please...
My buddy just bought an Evolution VIII and it is soo damn fast it pisses me off. I would really like it if my accord could beat it by the end of this year.
Anyways, I need to know whether i should buy an F22 block and build it up for the lowest comperssion possible to handle 25+ lbs of boost, or would the H22 be better for that. Ive heard really good things about turbo'd single cams, i just dont know cuz ive never done it. Any input would be greatly appreciated.
Old Feb 20, 2007 | 09:45 PM
sir_nasty's Avatar
Default RE: a little help please...
Generally speaking SOHC are better for turbo applications... His car is about 200 lbs lighter at roughly 286 HP so around 9.28lbs/hp depending on what year/model you have an F22 SOHC Vtec with 25 lbs of boost would spank him (assuming you have about a 94 accord at 2800 lbs) but it probably wouldn't be cheap
Old Feb 20, 2007 | 10:39 PM
Boogy's Avatar
Yeah i know it wont be cheap. His evo is running 26lbs of boost at 405 whp
Old Feb 20, 2007 | 11:22 PM
Boogy's Avatar
Do you know what needs to be done to lower the compression when i build the new motor?
Old Feb 21, 2007 | 07:38 PM
marbro's Avatar
lower compression has to do with the pistons, but you will need new rods and pistons anyways, basically you would look at an 8:1to 8.5:1 compression forged piston, and you will need to redo your valves, valve springs and a titanium retainer there are kits out there just for the head on f22's
THEN your options are close the deck or sleeve the block (personally i would sleeve the block so you can goto larger pistons but im sure others might say differently)
then of course you have to do the ecu bit, and larger injectors and a 3 bar map
and to all the others fill in what im missing ^_^
Old Feb 21, 2007 | 07:42 PM
sir_nasty's Avatar
I'd agree with sleeving.... and if he's at 405 WHP you're going to need to do some serious work.... new cam, headers, probably a larger coil to throw a hotter spark, I'd say for 10k-15k you'd beat him.... and considering he probably has $20,000 plus into his car (purchase price plus aftermarket) you'd kick his hiney for a lot less than he spent....
Old Feb 21, 2007 | 09:03 PM
Boogy's Avatar
Thanks alot guys. Do you know of any good names in the business that i could send the block and head to?
Old Feb 22, 2007 | 01:50 AM
marbro's Avatar
check locally first before you decide to send off your block to someone seeing as thats a good 300ish dollars for shipping, but i dont think you would go as high as $15k for the work engine work alone you can do foraround$6k to have it running properly tuning will be the biggest thing
but yeah, check local import shops, and gather info that way
Old Feb 22, 2007 | 01:53 AM
Boogy's Avatar
Alright sounds like a plan. Thanks alot
Old Feb 23, 2007 | 11:26 AM
HondaRacer4Vtec's Avatar
You can def take him even if you dont boost that crazy check out this vid.
http://www.youtube.com/watch?v=iJikbojHInI
