max boost on i4 auto
Old Jul 7, 2007 | 07:40 AM
BlkCurrantKord's Avatar
Default RE: max boost on i4 auto
Levelten sucks, ask around over at V6p.net. A valve body upgrade or shift kit isn't gonna do anything to help your tranny, the clutch packs are what see the abuse and go out.
Old Jul 8, 2007 | 12:45 AM
03Sleeper's Avatar
Some guy's Accord over at 7thgenaccord is basically 25% Acura. It's pretty ridiculous. Most of his Acura parts deal with the transmission and engine internals...(TSX, RSX). I call it the ASX (Accord Sport...Type X)
Old Jul 9, 2007 | 09:06 AM
leadfoot
yeah i know about level10 they suckbig ***. i wasnt thinking of going with them. but what i was plannng on doing was going ahead and geting the turbo, running 6-8 psi for a while. then get a 6-speed from a tsx and let it sit. then turn up the boost to see how much a can push it before it goes. then swap out the auto for the 6 speed .i guess u can say im going to find out the hard way how much horsepower this auto can hold. ill keep u guys posted.
Old Jul 10, 2007 | 12:10 PM
KevinAccord's Avatar
sure... it's ur money man.... i wouldn't do that, but thanxs for the info... keep it coming...
Old Jul 10, 2007 | 01:32 PM
sir_nasty's Avatar
I doubt I'd do it either but I would LOVE to help a friend do it so I could see what happens!
Old Jul 11, 2007 | 08:32 AM
leadfoot
i was poking around on ebay and found a tsx engine and tranny for sale $1200. so before getting the turbo installed i will be getting a spare engine and tranny. when the first engine and tranny goill put the turbo on the other motor. i was also thinking of slightlymodding the tsx block before installing it to run more boost. i figured with the tsx block and tranny and the turbo i should easily get 300whp. with low compresssion i will run alot more boost. my main goal is to be pushing over 20psi but i know thats going to be hard with the KA . anyone out there ever seen a low compression tsx with 20-25psi plus ???
Old Sep 5, 2007 | 09:30 AM
  #17
deathcrow's Avatar
I have accord auto k24a4 turbo.Boost 14 psi,tranny with cooler.Got 210 hp/5700 and torque 371nm(dyno dynamic).With small turbo td04 ar.63....This turbo not match for 2.4 lt...After 3700rpm flowless. Need up 1 or 2 level turbo size.
U can turbo ur stock car for max boost 0.8bar.No problem with ur auto tranny and internal.Just add cooler for tranny and engine.Over 0.8 bar... Need semi deck or closse deck ur block,down compression,strong piston and conrod.No need for head mod,coz auto tranny max rev 6500rpm.
Old Sep 5, 2007 | 09:34 AM
  #18
deathcrow's Avatar
I have accord auto k24a4 turbo.Boost 14 psi,tranny with cooler.Got 210 hp/5700 and torque 371nm/3700(dyno dynamic).With small turbo td04 ar.63....This turbo not match for 2.4 lt...After 3700rpm flowless. Need up 1 or 2 level turbo size.
U can turbo ur stock car for max boost 0.8bar.No problem with ur auto tranny and internal.Just add cooler for tranny and engine.Over 0.8 bar... Need semi deck or closse deck ur block,down compression,strong piston and conrod.No need for head mod,coz auto tranny max rev 6500rpm. Use redline oil for engine and tranny,check injector duty cycle(max 70%)n use walbro255(serie gss 341 or 342 be carefull many walbro fake)....Maybe next step u need racing clucth.No need to change torque converter.
Old Sep 5, 2007 | 02:41 PM
  #19
HondaRacer4Vtec's Avatar
you only got 210hp from 14psi, sry doesnt seem worth it
Old Sep 5, 2007 | 05:55 PM
  #20
agree.... got 214hp w/ 6psi on mine
