Turbo bought
Old Mar 17, 2006 | 12:56 AM
marbro's Avatar
Default Turbo bought
Welp, I have my t3/04e turbo sitting in my room. I am really hoping to find the "perfect" turbo manifold for a good price, but i dont know how long that will take.
Trying to find one small enough that i wont have to remove the a/c. Hope I wont pass the $600 mark for the turbo manifold and 5 bolt downpipe.
Old Mar 17, 2006 | 03:38 AM
lightshow's Avatar
Default RE: Turbo bought
a+ on your purchase. its not how small the manifold is but how its made..
Old Mar 17, 2006 | 10:56 AM
mbo1985's Avatar
Your downpipe is going to be the real deciding factor in keeping the a/c or not. If you go over a 2.5" d-pipe, you may have to get rid of it. Oh well, less weight and rotating mass, right?
Old Mar 17, 2006 | 02:52 PM
marbro's Avatar
Ive actually seen one that is a little shorter then the one mbo has it also has the flange out towards the front of the car. I am hoping to find one of those. But my problem is one of the hoses for the a/c goes across the fans, and in theory i should be able to get a 3 inch pipe if the manifold has the flange off set to the left of center
Old Mar 17, 2006 | 09:11 PM
mbo1985's Avatar
Yeah, if you can get a manifold from a drag or turbonetics kit (or any kit that is supposed to retain AC) you'll have a better shot at keeping the A/C.
Old Mar 18, 2006 | 09:06 AM
marbro's Avatar
yeah, the only manifold that ive seen that i would consider putting on my car are 400+ wish i were finding used ones.....
Old Mar 18, 2006 | 08:20 PM
lightshow's Avatar
your manifold should seriously cost about 200-250 dollars and you should have no prob keeping the a/c. keep looking.
Old Mar 18, 2006 | 08:27 PM
flomasta's Avatar
hey idk what engine you have but try f22parts.com
Old Mar 18, 2006 | 10:11 PM
marbro's Avatar
its an f23 engine, from what ive seen a lot of the f22 manifolds line up with the bolt pattern on my engine.
And f22parts have 2 different turbo manifolds, both of which were the design i was considering, but the cast iron one which has better flow is 500 http://www.f22parts.com/item_castturbomanifold.htm
and the stainless steel one is 400 http://www.f22parts.com/item_turbomanifold.htm and if you look at it, it doesnt scream design efficiency.
Old Mar 18, 2006 | 11:10 PM
accord_94's Avatar
they dont but the cast one it better built and they have better quality to them. yes they cost more but worth it.
