turbo or super?
Old Nov 15, 2008 | 03:22 PM
enigma07
Default turbo or super?
do they make any for the 03 accord v6, if so which one is better
Old Nov 15, 2008 | 05:02 PM
botang47's Avatar
Default RE: turbo or super?
yeah they do.
i would recommend a turbo because its powered by exhaust that would usually just be wasted and a supercharger is powered by the engine which in turn would take some power away from it.
but what do i know.
Old Nov 16, 2008 | 04:11 PM
skatingclaybird's Avatar
TURBO!!!!!
Old Nov 17, 2008 | 08:40 AM
falkore24's Avatar
SC for reliability and ease of use and tuning ..... IF the SC itself is not centrifugal.
Turbo for more power with less work, but tune is key to longevity. Reinforce all vacuum lines to ensure that you don't lose your intake reference and kill your motor. Also, if the only SC is centrifugal, you might as well get turbo since the cent. SC has all of the problems of both systems without the full power of turbo.
If you drive lightly, the turbo will have much better mpg. If you drive hard, the turbo has the ability to use much more gas as well.
Both systems require premium fuel as protection from knocking.
Turbo could cost much more depending on what accessories that you want. Also related to the uncertain operating conditions that is the nature of a turbo system whereas the SC is always spinning at a set rpm compared to the engine rpm.
Bottom line, it's your decision.
Old Nov 17, 2008 | 10:34 AM
finch13's Avatar
I have never seen a screw-type SC for the Accord... as far as I know only Comptech and Jackson make an SC kit and they're centrifugal.
Old Nov 19, 2008 | 10:26 PM
I have never seen a centifugal supercharger for an 03 accord
centrifugal is
http://www.aa1car.com/library/paxton_supercharger.jpg
ANd screw is
http://www.superchargersonline.com/i...c_cutaway2.jpg
and heres a SCREW type on an 04 (same as 03)
http://www.youtube.com/watch?v=Xu_IX...eature=related
Old Nov 19, 2008 | 10:37 PM
Accord Comptech superchargers are SCREW TYPE (Eaton) any ways
Do your home work HOMEWORK LOL
Old Nov 20, 2008 | 07:31 AM
falkore24's Avatar
I'm pretty sure that the one in your video is centrifugal (Comptech). Granted the video is a bit grainy, but I'm pretty sure that what you see in front of the engine is the SC drive shaft. According to the comments, there's a bag of ice on the volute. Another indication is the pipe that goes into the intake manifold. I could be looking at it wrong, but I don't think so.
Old Nov 20, 2008 | 12:05 PM
Centrifugal s/c look like a turbo right ...well the one in the video is screw type check my pic links and if this is so the CT S/c for accords are EATON SCREW TYPE
Old Nov 20, 2008 | 12:17 PM
http://images.google.com/images?um=1...=Search+Images
Here is centrifual S/C ^
Here Is the v6 ACCORDS S/C
http://www.autocarparts.com/part/list/928/
IF YOU READ THE FIRST LINE SAYS "SCREW TYPE" THaNK YOU
