Turbo yea
Old Sep 9, 2010 | 09:05 PM
Primerftw's Avatar
Default Turbo yea
Ok well after doing a lot of research and wanting to go N/A I decided I am going to turbo my 91 lx I have most of the stuff picked out I just need to get a complete list and start ordering parts but I was wondering what you guys think about this....I am aiming for 300hp with about 80k miles I am almost positive but am I going to be good on stock internals? (tuning is not an issue here)
Old Sep 9, 2010 | 11:41 PM
g22cd5's Avatar
Supper Moderator
you will make about 280-300 with a good tune with the parts you have. That will be enough power to run with if not walk on stock STI's...good luck!
Old Sep 17, 2010 | 12:05 AM
corvetteking's Avatar
It is all in your tune... If you have a great tune, the motor should last a while... How much boost are you planning on running???
Old Oct 2, 2010 | 05:58 AM
burninfuel's Avatar
I have a great idea for you, comp turbos make an oil-less turbo, you should get one of those because it you wont have to run oil lines or anything like that, just water lines. I am buying one for my mr2. but you will also need injectors, fuel pump, water lines, as well as a bunch of little stuff
Old Oct 9, 2010 | 01:57 PM
Primerftw's Avatar
ok well im debating on where to locate my oil return line on my oil pan should i put it up high on the pan middle to the driver side pass side or what? this is kinda confusing me and i really dont want to drill a hole and have to weld it back up
Old Oct 11, 2010 | 04:16 PM
g22cd5's Avatar
Supper Moderator
good question...cus I'm gonna have to do the same thing. Let me know what you find out. I would ASUME whatever is easier for you to run the return line...but I truly don't know...sorry
Old Oct 12, 2010 | 08:51 AM
You need to put it up high on the pan so it will function properly...also to decide which side, just look at the direction the line is coming off of your turbo and just use that side... Also FYI you really need to tap a bung in for you oil return... If u try to go the easy way out u will at some point have a leak...and the eBay stainless lines are just as good a any other, just upgrade the fittings on them... I use all AN fittings with welded in bunga...lemme know if u get any more questions
Old Oct 12, 2010 | 10:04 AM
g22cd5's Avatar
Supper Moderator
good info vettking! where you been haven’t seen you around the forums??
Old Oct 12, 2010 | 01:16 PM
Work, school, and a new baby... And new house... And a new project car... Haven't had a whole lot of time to post, but I'm trying to get back into t... If y'all need help with ur turbo setup lemme know... I'm on my 4th rodeo now...
Old Oct 12, 2010 | 02:13 PM
g22cd5's Avatar
Supper Moderator
ohh wow yeah you do have a lot going on..lol
Fo sho I deff. hit you up if I get into a snag...I'm sure I will not everything works 100% the 1st time..lol
