turbos??
Old Apr 7, 2009 | 12:33 PM
smcizme's Avatar
Default turbos??
ok, i hear a lot of ppl saying not to turbo a stock engine. So whats a stock engine? like i have a 99 accord coupe 2.3L and i want to swap out the engine but if i put in like an h22a engine, wouldnt that be a stock engine? so my main question is basically do i rebuild the engine to make it handle high psi for a turbo or is there an engine out there that handles well with a good turbo?
Old Apr 7, 2009 | 12:36 PM
Stock H22 is terrible for turbo(the higher the compression ratio the worse).
By "build" they mean dish pistons, upgraded con rods etc etc etc.
Old Apr 7, 2009 | 12:46 PM
smcizme's Avatar
so what would be the best engine to swap in that is compadable with a turbo?
Old Apr 7, 2009 | 12:49 PM
idk a d16? lol. wont really find anything that is "better" for a turbo stock than a f23
Old Apr 7, 2009 | 12:55 PM
smcizme's Avatar
ok so i keep my f23, but if i put a turbo on it it would only be able to hold at most 5-6psi, what would i have to do to get it up to like 12-13 psi?
Old Apr 7, 2009 | 12:59 PM
um a complete engine build, new pistons con rods, upgraded head.
Old Apr 7, 2009 | 01:21 PM
smcizme's Avatar
ok, so do you now anywhere that has a good rep. at rebuilding honda engines in the NJ PA area?
Old Apr 8, 2009 | 12:14 PM
falkore24's Avatar
There are a ton in Queens. My Accord was tuned by DRT in Queens. Kinda ghetto location, but an awesome shop. I used them because they are on the Apexi list of tuners for the V-AFC2 that I had.
A stock F23 is good for 6-8 psi. 6 psi should give you about 200whp. 12-13 psi will require new bearings, rods, and studs minimum.
Old Apr 8, 2009 | 12:21 PM
finch13's Avatar
RIPP Mods in Staten Island has done some nice work. Example:
Click the pic:
Old May 1, 2009 | 01:38 PM
KevinAccord's Avatar
wrong, 8psi. my f23 it's been boosting 7psi on a stock engine for almost 2 yrs and no problems.
not to mention I have a stupid AT. bought a MT and it got stolen from my backyard... sad man...
re sleeve and new pistons, rods, rings, .... idk... ect.
