04 Accord Help
Old Nov 6, 2008 | 09:22 PM
  #21
game0over's Avatar
Default RE: 04 Accord Help
Ok thanks guys
Old Nov 7, 2008 | 06:26 AM
  #22
falkore24's Avatar
Direct Port Nitrous
^^ here's a link to the nitrous sale thread. I'm actually not sure of what pills are in the kit ..... I'll have to look, but I'd expect 75 and 100 to be in there, probably a third set too, but I'll look and update the thread.
As far as raising the redline, don't do it! You've already stated that you don't have $$$$ to spend on this project and to raise the redline safely, you have to upgrade your valve springs and retainers, minimum. Lighter valves, new seats and guides are recommended to do at the same time and this will cost about $1500 just for the head work ....... mine's going to wind up costing about that and I'm doing the majority of the assembly and disassembly myself.
I also have a V-AFC2 for sale, but have been too lazy and busy to put a thread up for it ..... I actually think I had one at some point, but I can't find it. This would allow you to play with VTEC engagement and get a dyno tune.
Poly engine and tranny mounts will allow you to take off harder without wheel hop. Also, spinning the tires is much less dangerous to the car with them in place.
Lastly, power launching will shave off about 0.3-0.4 seconds if done right, but if you hold the stall rpm of the torque converter too long while braking, you will heat up the tranny and could cause problems.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
