350z sound
I was driving from school the other day and I see my teacher and his brand new 350.
The car looks super cool ( but i still wouldnt trade it for my baby ), and it sounds even better.
So just wondering if there is anything on the market for 7th gen v6 accord that would match that sound.
I checked magnaflow & they sound like an old v8 mustang. ( personaly im not a fan of muscle cars )
I dont want anything thats going to sound ricey either.
Tx for your help...
Tx for your help...
well..... the sound is going to be different in general because the 350z's engine has a bore of 95.5mm and a stroke of 81.4mm and a different varible valve timing, how its different from vtec, i dont know exactly. And finally a compression ratio of 10.3:1 Then the exaust flow is different because it has an equal distance of flow due to the rear wheel drive.
287 HP SAE @ 6,200 rpm
274 ft lb @ 4,800 rpm
the v6 06 accord has a 86.1 bore and an 86.1 stroke with a complession ratio of 10:1
244 hp @6250rpm
211 ft lb@ 5000 rpm
other then these obvious spec's it boils down to the air flow
i actually find it kinda funny, cause i was gold the 350z had 300hp, where that 287hp is the value at the crank, so both cars dont have a whp spec anywhere that ive seen at least
244 hp @6250rpm
211 ft lb@ 5000 rpm
its kinda hard to reproduce the same sound unless you have the same engine, because theres always something that will be a little off with it..... but its good to know i could beat a 350z with 12psi on mycar ^_^
cat2115
Apr 26, 2014 07:49 AM
HORSEPOWERJUNKIE2007
Mar 26, 2008 12:41 PM
iiisoysauceiii
May 5, 2005 05:52 PM
just kidding.
