launching
Old Jul 6, 2006 | 12:56 PM
2002haccord's Avatar
Default launching
i know theres a way to launch a manual transmission car is there a way for an auto
Old Jul 6, 2006 | 03:56 PM
sir_nasty's Avatar
Default RE: launching
you could try a power brake of sorts... put it down into first and hold the brakes tight, rev the engine up a bit and drop the brake and slam the gas and you should launch faster
Old Jul 6, 2006 | 05:17 PM
yeah cuz some dud pulled up next to m ame car as mine 4cyl accord coupe automatic and he was revving it and he just launched it was way quicker then me. he just had a cold airintake thats it and i have one too. i was just wondering thanks
Old Jul 6, 2006 | 09:42 PM
mbo1985's Avatar
my friend who has an auto mustang does something like what sir_nasty suggested with power braking. He basically stands on the prake pedal and floors the gas. Then when the light turns green he dumps the brake and the car takes off better than just stamping on the gas.
I wouldn't recommend doing that for a long time (like over 10 secs) since you're heating the trans fluid up more than you should. And never N - Bomb the thing! That's when you hold the revs at a certain RPM (say 4000 for instance) and just drop it into D. Not cool for your trans at all. I'd do the power brake thing if anything.
Old Jul 6, 2006 | 11:19 PM
YeuEmMaiMai's Avatar
I would not recomend power braking this auto trans on the V6 accord. IT is fairly fragile..........
Old Jul 7, 2006 | 02:16 AM
tom15425's Avatar
Curiousity compels me to ask, since it's an auto tranny and your starting it in D1, are the upshifts going to hurt the tranny at all being that it's not meant to be manually shifted?
Old Jul 7, 2006 | 11:02 AM
mbo1985's Avatar
I'm sure it's putting extra wear on the tranny. Ideally, a modified transmission would be best and would perform better.
On a side note, I shifted my old dodge truck's auto like a stick for years (ahh the joys of being a teenager) and I never had a problem with it, and to this day the tranmission runs fine. It is my dad's truck now and he doesn't even change the trans fluid ever (just doesn't believe in it). I'm not recommending abusing automatics, though.
Old Jul 7, 2006 | 11:36 AM
manually shifting the auto is pointless since the ECU already sifts at optimal points under WOT
