My Accord
Old Sep 24, 2012 | 12:29 PM
chaibatus's Avatar
Smile My Accord
Did following DIY jobs, 2000 Honda Accord EX v6 sedan, still going strong. Mileage 197,834. Any thing else which you guys would like to recommend?
9/1/2012 - engine filter,cabin filter and wipers
9/8/2012 - Transmission fluid, brake fluid and power steering fluid
9/8/2012 - Mobil 5w 30 High mileage oil change
9/8/2012 - Spark plugs,timing belt, all other belts and water pump
9/8/2012 - Ttiming belt, all other belts and water pump
9/8/2012 - Rotated tires, cleaned throttle body
9/8/2012 - Coolant flush
9/18/2011 - Replaced lower ball joints
Old Sep 24, 2012 | 06:49 PM
Only thing you might think about - dist cap and rotor - the OE wires on these seem to last forever.....
After that, a good wash and wax before old man winter shows up and enjoy
Old Sep 24, 2012 | 09:59 PM
Risingfallens's Avatar
I just got done replacing about 12' of vacuum line and a most of my coolant lines. Doesn't really do much performance wise, but usually you see a huge difference in a vacuum test. Then again I have a 96' and they've had time to dry rot. I'd say maybe even a bottle of seafoam. (I haven't done it yet, but from reading the bottle i'm gonna give it a try on Friday.) Maybe even give the PCV valve a shake, just to make sure its still running nice. Tune ups are always fun.
Old Sep 25, 2012 | 09:20 AM
You aren't gonna see ANY improvement in performance from vacuum lines & coolant hoses. But just wait for a coolant hose to rupture and spew antifreeze all over the place, and then you'll know why you need to do those things.
Old Sep 25, 2012 | 09:28 AM
chaibatus's Avatar
Poorman212, thank you for the advise. Planning to change the distributor cap and rotor over this coming weekend. Trying to shop around for the parts, do you want me to replace them with the OEM parts? please advise.
Old Sep 25, 2012 | 03:14 PM
Hondaswede's Avatar
I always take brakepadsoff and clean/lube up.Thats good to do on every Honda!Its the only weaknes i know about.
