pulling the e brake to "drift"
Old Apr 15, 2009 | 06:16 PM
najeezy's Avatar
Default pulling the e brake to "drift"
i have a 06 accord 4cyl, and ive tried to pull my e brake to powerslide, and the wheel doesnt lock at all. rather the car starts to beep and nothing happens.
is it a factory setting that the e brake doesnt lock the real wheels if theyre moving, or am i just not going fast enough or pulling the brake hard enough.
has anyone else had this problem?
Old Apr 15, 2009 | 08:37 PM
status's Avatar
um did you pull it up far enough? and turn the wheel?
how fast were you going?
Old Apr 16, 2009 | 01:08 PM
Briggz's Avatar
Almost A Senior Member
Haha... it works on snow... promise...
Old Apr 16, 2009 | 05:49 PM
najeezy's Avatar
i think my cable is loose. i pull that **** up hard, all the way, and im going at least 45-50, and nothing happens. i just slow down. very sadface :[
theres no snow in southern california. ever :[
Old Apr 16, 2009 | 10:14 PM
t00fatt's Avatar
I've never done it, but I'm sure my wheels will lock on my 06. I use my e-brake regularly when my radar detector goes off. I don't want the cop to see my brake lights go off the second he radars me. You have to be really careful though, and only slow down slowly.
Old Apr 16, 2009 | 11:02 PM
Vipers4Life's Avatar
That is genious! I never would have thought of that. I never pull my ebrake when I drive though. As for najeezy, trying to do those "Batman Turns" and calling them drifts in a FWD car is not worth it at all. Your cable is loose problably because of you trying to get your car to slide. Pulling your ebrake like that can kill the brake system, warp the rotors, break the friction material, crack a rotor, seize a caliper, etc. If you want to drift then go buy a RWD car like a miata(That car is crazy maneuverable!). No hard feelings ment from this but I'm trying to help you not damage your car
Old Apr 17, 2009 | 12:50 AM
status's Avatar
ok 40 to 50 i hope your on like an airport strip. i hope you dont try and drift.
edit
Old May 4, 2009 | 08:53 AM
dragonle87's Avatar
u probably have drum brakes....
I pull my & other ppl e-brake & it doesn't lock compare to rear disc brakes.....
Old May 4, 2009 | 09:40 AM
t00fatt's Avatar
The e-brake is a drum on every accord...
Old May 4, 2009 | 10:48 AM
Accord EX has rear disks. Occasionally they've include rear disks in some kind of LX special edition.
