Ticking sound
It’s a 2019 honda Accord sport 1.5L currently with 11k miles. Im the 1st owner.also when i press the gas and the turbo begins to engage and the metal shaft pulled out and pushes the air back in there is a metal grinding sound
here is a snippet of the other problem
Thanks, I updated the title a little bit, i ran across the forums and couldn't find the a thread discussing the issue i currently have so i hastily made a thread.
That's ok.
I've been working on a 14 4cyl and noticed the same issue. I was doing the 100k mi service and had to change the VC gasket because cyl 1 had a leak. I checked and adjusted the valves because the noise was as bad as yours. It got a little better but not by much (they were still within tolerance). I chalked it up to it being normal because of the direct injection engine (DI). The DI has a higher pressure which will cause the ticking noise.
That's ok.
Hello, Same issue my honda accord 2019, 44000 miles, start making noise please video, any suggestion will be appreciate it
Thank you
https://gemoo.com/tools/upload-video...05163747307520
Thank you
