South AR, LA, MS, KY, TN, AL, GA, FL, NC, SC, WV, VA, DE, DC, MD
Question about Wheels
Old Oct 1, 2023 | 05:20 PM
jwolfe18's Avatar
Default Question about Wheels
I know very little about after market wheels and have a question. I have a 2011 honda accord v6 coupe and am buying aftermarket wheels due to my 4 stock rims being bent. I have stock suspension and no mods to the vehicle. Will
18x8.5 F1R FS3 Gloss Black 5x4.5/114.3 38mm fit on my vehicle.
Thanks, Sorry for the font, I don't know how to change it back.
Old Oct 9, 2024 | 04:43 PM
Vecamia's Avatar
Yes, those wheels should fit your car:
- Bolt Pattern (5x4.5/114.3): This is a match for your car’s bolt pattern, so the wheels will fit the hubs correctly.
- Wheel Size (18x8.5): An 8.5-inch width is slightly wider than your stock wheels (typically 7.5 inches), but it should still fit well. You’ll need to pair them with the correct tires (such as 235/40R18 or 245/40R18) to avoid any issues with rubbing or clearance.
- Offset (+38mm): The stock offset is usually around +45mm. With a +38mm offset, the wheels will sit out 7mm more than the stock wheels. This is a small difference and shouldn’t cause any major problems, though the wheels will sit a bit closer to the fender. Since you're on stock suspension and don’t have any mods, it’s a straightforward fit. Just make sure you choose tires that work with the wheels and avoid anything too wide or tall that could cause rubbing. You should be good to go!
12guy20
Sep 30, 2011 05:11 PM
ryan48
Feb 9, 2011 11:00 AM
sICKWHIP
Mar 28, 2009 10:05 PM
tlhfirelion
Jun 18, 2008 09:47 PM
cwd40z
Mar 26, 2006 02:32 AM
