05 accord shocks?
Old Mar 11, 2007 | 10:37 PM
etexas
Default 05 accord shocks?
I have 62k on the car when i brake at highway speed the steering wheel shakes.. I think I'm due for some new shocks. I looked on net and cant find them in stock . Any help and advise would be great.
Old Mar 11, 2007 | 11:44 PM
trukid21's Avatar
Default RE: 05 accord shocks?
did you check your struts,shock mounts, steering column for anything loose.you might want tocheck your brake rotors and pads. my grand am use to do the same thing and i could not figure it out either. i balance the tires,check all my mounts and shocks and struts even my steering columnbutdid not find anything wrong.i replace my brakepads cuz they were worn. It stopped for a little bit but after a while it does it again. i discovered that onemy rotorswaswarped and the pads were wearing out unevenly with it. so,i had themcut within specs and put new pads againso basically they are both new.problem solved. try that one first,hopethis helps. goodluck.
Old Mar 12, 2007 | 12:09 AM
etexas
thanks i'll take a look they're the orginal brakes
ditbu13oi
May 8, 2007 05:56 AM
ohsmustangs09
Feb 12, 2007 07:31 PM
tommy
Jan 4, 2007 11:38 AM
putih
Sep 7, 2005 06:23 AM
