19" alloys for Honda Accord
Hi everybody
I'm wondering will such alloys fit my 99 ride:confused: Alloys are 19" widith:7,5J and offset is 35. tyres are 235/35/ZR19 Thanks for looking:) |
3 Attachment(s)
An offset of +35mm is WAY too low for an Accord. My 99 has +45 18" wheels on, perfectly flush with the fender.
This is +38mm on a 01-02 Accord with 18x9 wheels: Attachment 21450 Attachment 21451 Attachment 21452 |
Is there anything what I can do to make them fit??
Yes, drop the car on a $4,000 air bag system and run extensive negative camber so they don't rub.
It might look goofy, but they will fit and have the correctly sized tires. If you're lowered, they are almost guaranteed to rub on bumps. If you're not lowered, you should be fine. Also, stretching tires can be another way of getting them to fit, but most people don't like that look. (The pictures above are with stretched tires) Are the wheels being sold locally? You can always test fit them before you buy. |
Thanks alot:)
What did you do about the problem...?
I didn't bought those alloys:)
Thanks for all support:) |
Your very Welcome
WheelBrokerAng |
dont stretch your tires! its dangerous and stupid. if you want to make your car look good, buy 18's and just run it with some mild lowering springs. 19's would look so stupid. even those 18s are way too big imo. and besides, if you want ur tires to rip apart when u try a 1/4 mile, go ahead and stretch them. otherwise, get a high performance tire as wide as u can safely fit on the rim (it will say the acceptable rim width). and for god's sake, dont make it into an actual rice urner. that car u like prob has less than 200hp, a 0-60 of like 9 seconds and a 1/4 mile of like 17 or 18 at 85 mph, especially with those huge rims and ****ty stretched tires. get a quality set of proper tires and u will improve your handling dramatically. and imo, looks is bs if u cant perform. e.g. lamborghini murcielago (amazing looking car...**** on the track with more than one direction for turning) hence why nascar is stupid. anyway have a good one
