1995 honda accord suspension
Old Sep 5, 2007 | 01:10 AM
Orion123
Default 1995 honda accord suspension
I'm planning on lowering my car. I'm getting tein springs with kyb shocks.Do i need to get a camber kit also? If so, what is a inexpensive yet reliable camber kit? I'm also wondering how much it would cost to get all these things put on? And no i will do it myself cause i dont knwo anything. Thanks
Old Sep 5, 2007 | 11:30 AM
falkore24's Avatar
Default RE: 1995 honda accord suspension
1) add a signature with year/model/trim/doors
2) anything over a 1"drop will require a camber kit
3) do some research on your car because I killed the cheap front kit in under a year. The full upper control arm kit has been on my car for over 2 years since.
4) my install cost $400, a little over 3 years ago
5) re-read that last sentence. I think that you said the opposite of what you meant.
Old Sep 5, 2007 | 01:10 PM
thunder_x's Avatar
what do you mean by that?
did you buy a cheap brand camber kit and it broke on you?
Old Sep 6, 2007 | 10:39 AM
falkore24's Avatar
No .... it was the Ingalls offset ball joint. Apparently the 6th gens have very little clearance for this type of camber correction. When I had it on there, I had to grind off the edge of it so it wouldn't hit. A year later, I thought that I had an alignment problem because 1 of my front tires wore off the inner tread. When I had it looked at, we found that the rubber on both front adjustment pieces were dryrotted and falling apart. I did some research and found that Ingalls had experianced this problem and made the control arm version to correct it. So what I thought was an alignment problem became an alignment problem plus replacing parts on to of the 2 new tires.
Like I said earlier, he has to do the research on his car or he might end up spending extra money like I did.
v13tdragon
Jun 24, 2007 07:15 PM
Accordn2dis
Oct 19, 2006 12:26 AM
trickyvick
Mar 12, 2006 02:01 AM
George Knighton
Jan 11, 2006 08:49 PM
msmiz
Dec 22, 2005 09:05 PM
