2000 Accord LX Front Suspension Problem
Old Mar 15, 2013 | 02:02 PM
gciccol's Avatar
Question 2000 Accord LX Front Suspension Problem
Car: Used 2000 Accord LX with 198,000 miles.
Problem: Car is pulling to the left when driving.
Repairs: Purchased new tires, no change. Tried to get an alingment but shop could not do it. Said the left front tire is back 1/2 inch compared to the right front tire. Suggested there was frame damage.
Took it to a frame repair shop. They measured everything and said the frame was fine, all parts are original.
Took it back to the repair shop and they cannot find anything wrong with the left front suspension. Said everything measure out correctly. They're suggesting installing a full used left side suspension to see if it corrects the tire alingment.
Anyone ever have a similar problem where the tires is back in the wheelwell 1/2 inch but everything looks and measures correctly? I hate to repair this with a blind fix. Any info is much appreciated. Thank you.
Old Mar 15, 2013 | 04:54 PM
Do you have original tire sizes on the car?
Pulling is usually a camber issue. What was camber specs from alignment? Camber is not adjustable and adjustment requires fitting a modified connecting bolt between strut and lower arm, or new upper arm w/ adjustable ball jts.
You can measure camber. I bought the following inexpensive tool to check my vehicle camber.
S G Tool Camber Gauges Gauge with Magnetic Adapter ea 61800 | eBay
Note, this doesn't allow you to adjust but will confirm camber. You must measure on level ground or adjust for average cross slope of ground; subtracts from one side and adds to the other.
Old Mar 15, 2013 | 08:19 PM
One tire is back vs. the other side??
There's a radius rod connected to the lower control arm. That rod reaches forwards and fastens into a frame member sorta below the radiator. That attachment point way forwards is easy to overlook. Take a look & see if it's loose, bent or ???
Old Mar 16, 2013 | 11:50 AM
gciccol's Avatar
Thank you both for your excellent feedback. I'll follow up on your suggestions.
hammeru
Aug 17, 2011 05:25 PM
scotboxer
Jul 14, 2010 01:42 PM
97mugenaccord
Jun 4, 2010 04:16 PM
m626gt
11
Mar 1, 2009 12:49 AM
George Knighton
Jan 11, 2006 08:49 PM
