94 accord loose rear end
Old May 13, 2009 | 09:05 PM
robertaccord
Default 94 accord loose rear end
i have a accord that rear end does not like rough roads or bumps in the road and the rear sways back and forth while driving. is it my sway arm or other things?
Old May 15, 2009 | 02:12 PM
draser's Avatar
Sounds like shocks, try to push down hard on each corner and you should see it come up and stop. If it bounces up and down it needs the shock absorber replaced, and you'll need to replace both sides. Depending on your mileage and the roads you travel, you may need shocks all around.
Is there noise with the bouncing, clunks, etc?
If you have suspension work done, that'll be the time to have arm bushings inspected for play, sway bushings and links, ball joints play, bent arms and secured fasteners.
92AccordOwner
Jul 31, 2011 10:02 AM
muddydec
Apr 14, 2008 08:30 PM
Trake99
Nov 20, 2007 02:01 AM
brownstreak
Sep 23, 2006 08:46 PM
legionofone
May 30, 2006 09:46 AM
