coilovers installed correctly?
i bought the car with these already on here, and was wondering if they are installed right. i am assuming that they are ajustable. if so how do i raise the front up a lil bit?
http://i37.photobucket.com/albums/e8...k/001jpg-2.jpg http://i37.photobucket.com/albums/e8...k/002jpg-3.jpg |
RE: coilovers installed correctly?
Uh... why is the spring not sitting in the perch in the second pic. To adjust them you just turn the bottom (threaded) part with the wrench that should have come with them.
i currently have the car jacked up trying figure out the tanns pan leak, and happened to notice them. also i didn't get a wrench with the car. i'm lucky i got the lug nut tool
Oh, yeah you can get the wrenchs online and what not or try twiting them with your hand. shouldn't be too difficult with no pressure on the spring.
ORIGINAL: finch13 Oh, yeah you can get the wrenchs online and what not or try twiting them with your hand. shouldn't be too difficult with no pressure on the spring. |
so the farther apart the two are the hight the car?
No .... the 2 plates are the spring perch and the locking plate for it. They have to be tightened together, but to adjust your height, you loosen the locking plate, adjust the perch and tighten the locking plate to the perch in it's new position.
The tools are called "Spanner Wrenches" in case you plan on buying a set. J_man: A chisel is fine to lock the perch in place or to loosen a really tight perch, but I'd prefer the wrenches for most of the adjustment so you don't put so much pressure on the shock sideways. |
ok cool. now i know
