coilovers installed correctly?
Old Jun 26, 2008 | 01:29 PM
squeek's Avatar
Default coilovers installed correctly?
i bought the car with these already on here, and was wondering if they are installed right. i am assuming that they are ajustable. if so how do i raise the front up a lil bit?
http://i37.photobucket.com/albums/e8...k/001jpg-2.jpg
http://i37.photobucket.com/albums/e8...k/002jpg-3.jpg
Old Jun 26, 2008 | 01:35 PM
finch13's Avatar
Default RE: coilovers installed correctly?
Uh... why is the spring not sitting in the perch in the second pic. To adjust them you just turn the bottom (threaded) part with the wrench that should have come with them.
Old Jun 26, 2008 | 01:37 PM
squeek's Avatar
i currently have the car jacked up trying figure out the tanns pan leak, and happened to notice them. also i didn't get a wrench with the car. i'm lucky i got the lug nut tool
Old Jun 26, 2008 | 01:47 PM
finch13's Avatar
Oh, yeah you can get the wrenchs online and what not or try twiting them with your hand. shouldn't be too difficult with no pressure on the spring.
Old Jun 26, 2008 | 08:31 PM
j_man_honda's Avatar
ORIGINAL: finch13
Or you can take a chisel, put it in one of the slots and tap it with a hammer to loosen or tighten the sleeves. Thats how i do mine so i know theyre snug
Old Jun 26, 2008 | 08:45 PM
squeek's Avatar
so the farther apart the two are the hight the car?
Old Jun 27, 2008 | 11:02 AM
falkore24's Avatar
No .... the 2 plates are the spring perch and the locking plate for it. They have to be tightened together, but to adjust your height, you loosen the locking plate, adjust the perch and tighten the locking plate to the perch in it's new position.
The tools are called "Spanner Wrenches" in case you plan on buying a set.
J_man: A chisel is fine to lock the perch in place or to loosen a really tight perch, but I'd prefer the wrenches for most of the adjustment so you don't put so much pressure on the shock sideways.
Old Jun 27, 2008 | 07:20 PM
squeek's Avatar
ok cool. now i know
accord2010
Mar 4, 2010 12:43 AM
IntoTheGround
Dec 10, 2009 02:24 PM
AccordLXMaster
Dec 8, 2008 03:39 PM
dfeat01
Apr 25, 2008 09:23 AM
