do ebay camber kits work?
Old Nov 8, 2006 | 02:08 AM
thunder_x's Avatar
Default do ebay camber kits work?
yea, camber kits are expensive...
sometimes even more than the springs themselves
Old Nov 8, 2006 | 03:48 AM
Default RE: do ebay camber kits work?
All camber kits work as long as they are the right ones for the application your buying them for.
Old Nov 8, 2006 | 04:49 AM
YeuEmMaiMai's Avatar
the question should be "how long will the e-bay camber kits last?"
E-bay is a place filled with many bargains and many counterfiet parts.
Old Nov 8, 2006 | 12:12 PM
I'm going to say that if you buy a brand name set of camber kits that they will last a long time a no name company is usually also good but they dont have a track record of users to help you make a decision on buying or useing their products.
Hope this helps out on your question YuemMaiMai.
WheelBrokerAng[sm=americanasmiley.gif]
Old Nov 8, 2006 | 01:38 PM
sir_nasty's Avatar
I'll support wheelbroker 100% on that... Stick with a reliable name or do a LOT of research on an off brand product before you buy it...
Old Nov 8, 2006 | 07:16 PM
thunder_x's Avatar
how about the correct degree/angle of adjustment?
all camber kits dont adjust the same angle, right?
how would i know what i need to adjust, or will the shop just figure all that out for me?
Old Nov 8, 2006 | 09:20 PM
sir_nasty's Avatar
the shop should adjust that as part of an alignment, most camber kits will give you +/- 3 degrees which should be more than enough
Old Nov 8, 2006 | 11:50 PM
thunder_x's Avatar
what if i got some coil overs and my car was dropped 2 inches with the camber corrected
then one day i decided to drop my car another inch to make it 3, wouldnt my camber be off again?
Old Nov 9, 2006 | 03:10 PM
sir_nasty's Avatar
if you dropped it 2 inches the adjusted camber then dropped it another inch to 3 then yes your camber would be off again.... however, they say you can safely run +/- 1 degree of camber so as long as it didn't go past that threshold you'd be okay... but most likely yes you would need it adjusted again
Old Nov 9, 2006 | 07:18 PM
thunder_x's Avatar
alright, then i take it back to the shop for the adjustment, or i do it myself?
and how long does it take for the adjustment of the camber?
