Dropping 1"-2"
Old Nov 18, 2008 | 10:50 AM
  #41
cjdm98's Avatar
Default RE: Dropping 1"-2"
Im sure you had negative camber on that setup finch.
Old Nov 18, 2008 | 10:57 AM
  #42
finch13's Avatar
Not yet, hard to have neg. camber when it's sitting your bedroom
Pics for sure, I'm riding on Teggy-sized tired right now so I will probably be dragging the car on the ground. I already scrape on everything with the stock suspension.
I'm going to my favorite alignment shop and hotrod buddy and he'll let me sit in the car while he aligns it. $80.
I'm also debating on whether to drop the perches on the Koni's as low as they go... then it will be 2.5R/3.0F... we'll see.
Old Nov 18, 2008 | 11:06 AM
  #43
ORIGINAL: finch13
that is what we call "dumped"
Old Nov 18, 2008 | 11:11 AM
  #44
finch13's Avatar
Yesh, I may tuck some tire and run negative camber for a while on my Toyo's, with a treadwear rating of 580 I'm not too worried about them, then I'll buy rims in the summer and correct the camber
Old Nov 18, 2008 | 11:13 AM
  #45
cjdm98's Avatar
3 inches is drastic..
Old Nov 18, 2008 | 11:51 AM
  #46
falkore24's Avatar
Major bump steer with that dumpage!
Old Nov 18, 2008 | 12:02 PM
  #47
finch13's Avatar
The suspension shouldn't compress all that much with those springs, so the bump steer will probably be 1-2ft.
Old Nov 18, 2008 | 12:27 PM
  #48
falkore24's Avatar
the more you drop, the more bumpsteer you get ..... unless of course you lower the steering rack.
Old Nov 18, 2008 | 01:06 PM
  #49
finch13's Avatar
Can you explain bump steer more? I thought it was the amount the wheels toe in when you compress the suspension...
Old Nov 18, 2008 | 03:03 PM
  #50
falkore24's Avatar
No time now, but look up the Ingalls suspension primer .... I think that touches on it.
