Eibach pro-dampers
Anybody using Eibach pro-dampers here? I want to buy one to put with my existing Eibach sportline springs. My sportlines is running a little bit bumpy with the stock shocks so I'm thinking of upgrading the dampers. Thanks!
RE: Eibach pro-dampers
no im running tokico but i know that eibach is a good company im sure that you will behappy with them...especially if they are adjustable
nobody seems to be using the eibach pro-dampers, I can't find any reviews so I decide to go with the Koni yellows which is tried and tested already.
seriously cant get much better than koni. i had two setups that i really wanted to go with when i was thinking about suspension. tein springs over tokico struts, or comptech springs over koni's
If you could afford the Eibach Pro Dampers then go for it. They are a good reputable company that does their R&D. I'm riding on their sportlines with koni yellows and I can't argue with the package. The height is minimally adjustable with the C-clip on the koni's(which is actually pretty nice considering they arent coilovers) and the dampening adjustability is kick-ass. The firmest setting is rough as hell but corners like no other and the softest setting also corners nicely and has a close to stock feel. I love the setup as it is now. Eibach and koni have alot to offer for their buyers.
Hi! Do you have the 7th gen accord? I got my Konis today but not a lot of hardware is included unlike the other Koni users have. Does the washers, spacer and bushing from the stock shcoks fit the Koni yellow for the 2005 accord that is why they didn't include much hardware on the package? Does it adjust the compression and rebound at the same time on the same adjustment knoob? thanks!
You made youself a good choice here with the KoNI's, they have a good following with the Honda crowds at the car shows-so you know you will be in with the popular crowd...
WheelBrokerAng :eek: ORIGINAL: jhec23 nobody seems to be using the eibach pro-dampers, I can't find any reviews so I decide to go with the Koni yellows which is tried and tested already. |
Eibach Sportlines and Konis-nice ride and quality. The Koni Fronts are like 1-1/2 turns and its pretty stiff already.
[IMG][/IMG]http://i33.photobucket.com/albums/d9...n/DSC00074.jpg |
