Eibach pro-dampers
Old Apr 3, 2006 | 06:35 PM
jhec23
Default Eibach pro-dampers
Anybody using Eibach pro-dampers here? I want to buy one to put with my existing Eibach sportline springs. My sportlines is running a little bit bumpy with the stock shocks so I'm thinking of upgrading the dampers. Thanks!
Old Apr 5, 2006 | 04:50 PM
lightshow's Avatar
Default RE: Eibach pro-dampers
no im running tokico but i know that eibach is a good company im sure that you will behappy with them...especially if they are adjustable
Old Apr 6, 2006 | 07:45 PM
jhec23
nobody seems to be using the eibach pro-dampers, I can't find any reviews so I decide to go with the Koni yellows which is tried and tested already.
Old Apr 7, 2006 | 06:32 AM
lightshow's Avatar
seriously cant get much better than koni. i had two setups that i really wanted to go with when i was thinking about suspension. tein springs over tokico struts, or comptech springs over koni's
Old Apr 13, 2006 | 04:12 AM
LinX's Avatar
If you could afford the Eibach Pro Dampers then go for it. They are a good reputable company that does their R&D. I'm riding on their sportlines with koni yellows and I can't argue with the package. The height is minimally adjustable with the C-clip on the koni's(which is actually pretty nice considering they arent coilovers) and the dampening adjustability is kick-***. The firmest setting is rough as hell but corners like no other and the softest setting also corners nicely and has a close to stock feel. I love the setup as it is now. Eibach and koni have alot to offer for their buyers.
Old Apr 13, 2006 | 06:44 PM
jhec23
Hi! Do you have the 7th gen accord? I got my Konis today but not a lot of hardware is included unlike the other Koni users have. Does the washers, spacer and bushing from the stock shcoks fit the Koni yellow for the 2005 accord that is why they didn't include much hardware on the package? Does it adjust the compression and rebound at the same time on the same adjustment knoob? thanks!
Old Apr 13, 2006 | 10:31 PM
You made youself a good choice here with the KoNI's, they have a good following with the Honda crowds at the car shows-so you know you will be in with the popular crowd...
ORIGINAL: jhec23
Old Apr 23, 2006 | 01:43 AM
birdman's Avatar
Eibach Sportlines and Konis-nice ride and quality. The Koni Fronts are like 1-1/2 turns and its pretty stiff already.
[IMG][/IMG]
otsb708
Sep 12, 2009 12:38 PM
StrikingAccord
16
Jul 2, 2009 05:55 PM
glen e
Mar 5, 2009 03:58 PM
thunder_x
May 6, 2006 04:33 AM
ONEwickedACCORD
Nov 11, 2005 03:02 AM
